김대윤의 블로그 - DaeYun Kim's Blog
[Recording for Webinar] QbD Using JMP Part I (2020. 5. 28)
2015. 5. 7 ~ 2016. 10. 21일까지 연재된 QbD Column을  Webinar로 진행합니다.
2020. 5. 26일 진행된 QbD Using JMP Part I은 아래의 3개의 주제에 대해 진행했으며, DoE 중 완전요인배치(Full Factorial) / 부분요인배치(Fractional Factorial) 디자인 사례를 살펴보았고, Design Space를 왜/어떻게 설정할 수 있는 지에 대해 알아보았습니다.
The QbD Column: Overview of Quality by Design
The QbD Column: A QbD factorial experiment
The QbD Column: A QbD fractional factorial experiment
(view in My Videos)
QbD를 수행하는 데 있어 JMP Software 가 얼마나 Powerful하고 손쉽게 접근할 수 있는지, 그리고 JMP만의 강력한 DoE 기능에 대한 이해와 다양한 시각화 tool을 활용한 Insight 도출을 하는 방법에 대해 살펴보았습니다.
QbD Using JMP Part II (2020. 6. 25 예정)도 많은 관심 부탁드립니다.
Last Modified: May 28, 2020 2:44 AM
Comments
rkenett
Level III
Watched the video you did of Part I of our QbD column. Did not understand anything but it sounded very impressive ...:-)
Will be glad to help in follow up videos. I obviously have all he JMP files and the video could provide a live demo.
Also, I assume you are aware ot the QbD update blog recently published in the community of JMP blogs A QbD update: Current and future trends in Quality by Design
DaeYun_Kim
@rkenett Dear Ron,
Thanks for your comment and willingness to help.
I have already asked you to provide your QbD Column post's JMP data table, and you gave me gladly.
I planned this webinar in Korean 3 parts with your QbD Column blog post.
When I need your further help, I will let you know.
Thanks again and be healthy.
Best
DaeYun
rkenett
Level III
Yes - thank you for connecting the dots. There is also a chapter on Quality by Design in my book on Modern Industrial Statistics with application sin R, MINITAB and JMP (Wiley, 2014) which will soon come out in its third edition. It is available in Vietnamese and Spanish and has a Chinese edition.https://www.wiley.com/en-us/Modern+Industrial+Statistics%3A+with+applications+in+R%2C+MINITAB+and+JM...
