The Discovery Summit 2025 Call for Content is open! Submit an abstract today to present at our premier analytics conference.
View Original Published Thread
How to fix the JMP ribbon disappearing from the Excel menu
When you first install JMP, you can install the Excel add-in as follows:
undefined
However, some people did not select the above function during initial installation, or experienced the disappearance of the JMP add-in menu in Excel while using JMP.
In this case, please proceed as follows.
1. (If open) Close JMP.
2. Using the control panel , select “Change” program .
undefined
3. Select “Modify” program below
undefined
4. Reinstall the “ Excel Add-in” below.
undefined
The above is also explained in detail in the following link:
JMP Note 575299 - How to install or re-install the Excel Add-in for JMP® when the JMP tab does not appear in Microsoft Excel
If the above method does not work, then try reinstalling Excel (or Office).
This post originally written in Korean and has been translated for your convenience. When you reply, it will also be translated back to Korean.
