Don’t miss your chance to experience Discovery Summit Europe at our best available rate! Early bird registration through 31 Oct.
Graph Builder Toolbar streamlines interactive graphing. Creates shortcuts on Report and GraphBuilder Helpers toolbars. Download and install the extension.
I wasn't sure where this project would go. The attached JSL script (below) generates images to a desktop folder (create it first) that can be combined into a video using other video creation software. I used Blender's NLE; there are packages with shorter learning curves.
Making no apologies for the script, it was a work in progress, and then it was done.
There is something happening in the first 7 seconds, but it might not be visible in a small view. After that, every pixel is changing in every frame, and the video compression gets a workout.
flock.jsl
Last Modified: Nov 14, 2016 4:36 AM
