Uncharted
Craige_Hales
MFI from Selected CSVs in a ZIP
@Richardli  asked unzip + multi file import
filename = Pick File( "Select zip File", "$DOCUMENTS", {"ZIP Files|zip", "All Files|*"}, 1, 0 );
// "/C:/Users/v1/Documents/saveappend.jmpaddin.zip"
If( filename != "" & File Exists( filename ), // check for canceled
	za = Open( filename, "zip" );
	listOfMembers = za << dir; // {"addin.def", "addin.jmpcust"};
	// build the gui list of checkboxes
	lb = Lineup Box( N Col( 3 ), spacing( 20 ) );
	For( i = 1, i <= N Items( listOfMembers ), i += 1,
		lb << append( Check Box( listOfMembers[i] ) )
	New Window( "select members",
		lb,
		Button Box( "import selected",
			dir = Convert File Path( "$temp/deleteMeCSV/" ); // "/C:/Users/v1/AppData/Local/Temp/deleteMeCSV/"
			//delete directory(dir);// be CAREFUL !!! you might want to clean up before or after, but it does delete all the files!
			Create Directory( dir );
			Show( N Items( lb ) );
			names = "";
			For( i = 1, i <= N Items( lb ), i += 1,
				If( lb[i] << get/* is checked */,
					name = (lb[i] << get selected)[1]; // name of checked box is name of member
					names = names || name || ";"; // explicit list of names, in case dir has old names
					csvdata = za << read( name, Format( "blob" ) ); // load as blob, just in case
					name = Save Text File( dir || name, csvdata ); // save for mfi
			Multiple File Import( <<Set Folder( dir ), <<Set Name Filter( names ), <<Set Name Enable( 1 ), /* more parms here */ ) << Import Data;
Last Modified: Nov 23, 2021 8:47 AM
