Uncharted
Craige_Hales
Factory Art
Not-quite-random art generator.  Notice the paint function's use of matrix indexing to avoid an explicit JSL loop to set a vertical line of pixels, more-or-less perpendicular to the path of the brush.  M selects the pixels and blend1 & blend2 make the center of the wide brush stroke opaque and the edges more transparent.  (Off-shoot of another project, inspired in part by Dynamic Image Generation with Python – SWHarden.com.)
FactoryArt - YouTube
Window( "x" ) << closewindow;
scale = 4;
brows = 1080 * scale;
bcols = 1920 * scale;
red = J( brows, bcols, 0 );
green = J( brows, bcols, 0 );
blue = J( brows, bcols, 0 );
imageno = 0;
paint = Function( {row, col, color, drow},
    {m = Max( 1, Min( brows, row - drow ) ) :: Min( brows, Max( 1, row + drow ) ), r, g, b, blend1 = ((1 :: Max( 1, Floor( N Cols( m ) / 2 ) ))
     || If( N Cols( m ) > 1,
        (Ceiling( N Cols( m ) / 2 ) :: 1),
    ))` / Ceiling( N Cols( m ) / 2 ), blend2 = 1 - blend1},
    {r, g, b} = Color To RGB( color );
    Try(
        red[m, col] = (red[m, col] :* blend2 + r * blend1);
        green[m, col] = (green[m, col] :* blend2 + g * blend1);
        blue[m, col] = (blue[m, col] :* blend2 + b * blend1);
        Show( exception_msg, row, col, r, blend1, blend2, drow, m );
        Stop();
stripe = Function( {amp1, reps1, phase1, reps2, phase2, row, h1, h2, mindr, maxdr},
    {ic, ir, fract, dr, color},
    reps1 *= 2 * Pi();
    reps2 *= 2 * Pi();
    phase1 *= 2 * Pi();
    phase2 *= 2 * Pi();
    amp1 *= scale;
    mindr *= scale;
    maxdr *= scale;
    For( ic = 1, ic <= bcols, ic++,
        fract = ic / bcols;
        ir = row + amp1 * Sin( phase1 + reps1 * fract );
        dr = Interpolate( Sin( phase2 + reps2 * fract ), -1, mindr, 1, maxdr );
        color = HLS Color( Interpolate( fract, 0, h1, 1, h2 ), .5, 1 );
        paint( ir, ic, color, dr );
        If( Mod( ic, 512 ) == 0,
            Wait( .01 );
            img = New Image( "rgb", {red, green, blue} );
            img << scale( .5 );
            img << saveimage( "\VBOXSVR\windowsShare\painter\pics\p" || Right( Char( imageno++ ), 6, "0" ) || ".jpg", "jpg" );
picture = Function( {nstripes},
    {istripe, fract, hue1, hue2},
    For( istripe = 1, istripe <= nstripes, istripe++,
        Show( istripe );
        fract = istripe / nstripes;
        nfract = 1 - fract;
        thisrow = Random Integer( brows / 200, brows - brows / 200 );
        rfract = thisrow / brows;
        hue1 = Random Uniform( .8 * rfract + .3, .8 * rfract + .3 );
        If( hue1 > 1, hue1 -= 1 );// alow h1 wrap around
        hue2 = hue1 + Random Uniform( 0, .2 );
        If( hue2 > 1, hue2 = 1 );// prevent wrap around for h2
        stripe(
            Interpolate( fract, 0, 50, 1, 10 ), // amp1
            Random Uniform( .1, .4 ), // rep1
            Random Uniform( 0, 1 ), //phase
            Random Uniform( 0, .2 ), // rep2
            Random Uniform( 0, 1 ), // phase2
            thisrow, // target row
            hue1,
            hue2,
            5, // min delta
            Random Integer( 5 + 25 * nfract, 50 + 150 * nfract ) // max delta
picture( 100 );
Wait( 0 );
img << scale( .5 );
New Window( "x", img );
Last Modified: Oct 18, 2016 11:48 PM
