  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Uncharted
Craige_Hales
Embedded Log on Right
I use the embedded log a lot:
Right-click to get the popup.Right-click to get the popup.
The code editor is shortened, top-to-bottom, and the log is quite wide:
I'd like more vertical space in the upper editor.I'd like more vertical space in the upper editor.
Run this and it is fixed!
(Current Window() << child) << sethorizontal( 1 );
A narrow log is fine; usually I'm just watching for an error message.A narrow log is fine; usually I'm just watching for an error message.
I like this on a landscape display.
I'm also experimenting with a proportional font. I'm not sure why all code editors think a mono-spaced font should be default...I think it is a hold over from 80-column punched cards.
Last Modified: Jan 7, 2022 10:17 AM
Comments
Craige_Hales
A wish-list already exists Allow Log window to be reorganized
SamGardner
Level VII
This is great, thanks for posting!  I have already added this to my personal collection of utility scripts.
SamGardner
Level VII
Is there a message that can be sent to the script window to check to see if the embedded log is turned on and also then to turn on or off the embedded log display?
Craige_Hales
Thanks! I did not spend much time searching, but I did not figure out how to script show embedded log. It is in the prefs, but that's too late after the editor is open. You can check the horizontal flag, but that doesn't tell you much unless you just want to toggle it.
Adding a like to the wish list will probably help this get some attention.
Craige_Hales
JMP 16 (not sure about 15 and earlier) already does this nicely in a project. Use the project menu to add the log window and dock the window (drag with mouse) where you want it.
Once docked, on the right in my case, it reopens in the same place when the project is opened, and is shared by all the tabs.Once docked, on the right in my case, it reopens in the same place when the project is opened, and is shared by all the tabs.
