gail_massari
Fitting Repeated Measures Data using JMP Pro
See how to:
  • Use repeated measures to model correlation structures
  • Organize data, graph correlations, build models, compare/select the best model and test hypotheses
  • Interpret statistics related to mix models
  • Understand Toeplitz, ante-dependent and compound symmetry (equal variances) covariance structures
  • Deploy AR(1) model that assumes degradation rate constancy over time
  • Deploy Toeplitz model that has different degradation rates for different time periods
  • Deploy random coefficients (random intercept/random slope) models to model random effects
  • Interpret Repeated Effects Covariance Parameter Estimates
  • Compare models
Resources
Article Tags
Use Videos and Resources to Practice JMP, JMP Pro, JMP Clinical and JMP Genomics.
1-hour live Mastering JMP webinars occur most Fridays from January through October. After each session, we hope you will use the video and resources shared by the presenting JMP Systems Engineers to practice what you saw.
Mastering JMP Videos are available here.
