The Discovery Summit 2025 Call for Content is open! Submit an abstract today to present at our premier analytics conference.
See how to use to use Text Explorer to glean valuable information from text data at April 25 webinar.
The JSL Cookbook II
The New JSL Cookbook is finally here! It is a revamp of the old Cookbook to offer recipes that are more accessible and general.
On the main page you’ll see four sections: Appetizers, Main Courses, Side Dishes, and Desserts. In general, the sections will go from basic to advanced. Appetizers will be used for recipes about fundamental tools in JSL, like Script Window and the Debugger. The focus won’t be on code writing, but things to help you write code better and faster. The center of attention in Main Courses will be JSL objects: tables, journals, platforms, etc., as well as basic input-output. While many of the operations in this section will become simpler as the Action Recorder develops, there will always be a need to tweak automatically generated code. Side Dishes gets into some of the nuts and bolts of JSL, things like looping, branching, error trapping, and so on. Recipes that take your JSL skills to the next level will be found here. Finally, the Desserts section will contain recipes going above and beyond everyday scripting. Here you’ll find items covering both advanced topics and JSL based JMP applications, such as the Application Builder.
Here are the starting nine recipes in the Cookbook:
Appetizers
The Script Window – Basics
Using the Script Widow – Next Steps
Main Courses
Join 2 Tables and Create a Subset
Modify a Report Based on Analysis Results
Build a Tailored Report using Messages
Concatenate CSV Files Selected by User
Side Dishes
Using a Dialog Box to Create a Tailored Report
Desserts
Accessing Information using REST/API – Getting Started
Running a Platform without Knowing the Number of Names of Columns
Tags will be used to cross reference topics to recipes. Here is the current list:
Tag
Recipes
Enhanced Log
The Script Window – Basics (Appetizers)
Join 2 Tables and Create a Subset (Main Courses)
Build a Tailored Report using Messages (Main Courses)
Script Editor
Using the Script Widow – Next Steps (Appetizers)
Scripting Index
Modify a Report Based on Analysis Results (Main Courses)
Data Table Objects
Colors
Platform Objects
Report Objects
XPATH
Input-Output
Concatenate CSV Files Selected by User (Main Courses)
Lists
String Manipulation
User Input
Using a Dialog Box to Create a Tailored Report (Main Courses)
Dialogs
Accessing Information using REST/API – Getting Started (Desserts)
Expression Handling
Running a Platform without Knowing the Number of Names of Columns (Desserts)
Associative Arrays
REST/API
The New Cookbook is meant to be a living document. In the coming months we will be adding more recipes, tagged topics, and resources links. We will use this blog as place to post questions and comments about the Cookbook. We would also like to encourage you to submit your recipe for inclusion into the Cookbook. We ask for the completed code and recipe instructions, similar to what you currently see attached to the recipes. The documents should be editable. You don’t have to record yourself performing the recipe.
That’s it for now. Hope you enjoy. Bon Appetit!
Comments
