Semiconductor JMP Users Group Discussions
nina_chan
Time to Innovate Sept 19: Best practices by Vishay Semiconductor Italiana
Time to Innovate.pngOn September 19 Fabrizio Ruo Redda, Senior Manager of R&D at Vishay Semiconductor Italiana is our guest at "Time to Innovate". He'll speak about how Vishay has embraced democratization of data analysis and how JMP has helped them to spot trends in the industry faster and reduce time to market.
Fabrizio will highlight how applying lean principles to the engineering data analysis flow at Vishay, typically used in manufacturing, helped reduce time wasted on “data movement.”
By introducing a new data management system using JMP and SQL databases, they eliminated inefficiencies, allowing engineers to focus on analysis rather than data handling.
There will also be presentations by JMP Systems engineers Emmanuel Romeu and Massimo Martucci on data cleaning and exploratory data analysis.
The event is taking place at 11 am Central European Time. If the time zone does not work for you, sign up anyway and we'll send you the recording. Exceptional Efficiency Through Exploratory Analysis and Effective Workflows | JMP
Feel free to share the event with your colleagues. Here is a recent LinkedIn post you could share: https://www.linkedin.com/feed/update/urn:li:activity:7239182264847269888
0 REPLIES 0
