Ryan DeWitt Blog
JMP Videos and Tutorials
ryandewitt
JMP Workflow Builder - 60 Seconds
JMP's Workflow Builder is a game changer. If you've ever wanted to capture your data prep or analytic workflow, JMP 17 has you covered. Don't let this 60 second video fool you, it's just an introduction.
The Workflow Builder is a JMP utility to capture, build, manage, and share data preparation and analysis workflows. The Workflow Builder uses the Enhanced Log to capture actions as you work in JMP. Use the Workflow Builder to do any of these actions: automate a workflow, share a workflow, re-run a sequence of steps with new data and archive or document an analysis.
Learn more
Developer Tutorial: Using Workflow Builder to Share Analysis Steps for Replay – No Coding Required
https://community.jmp.com/t5/Mastering-JMP/Developer-Tutorial-Using-Workflow-Builder-to-Share-Analys...
Last Modified: May 31, 2023 9:49 AM
