Try the Materials Informatics Toolkit, which is designed to easily handle SMILES data. This and other helpful add-ins are available in the JMP® Marketplace
jshaw04
Level III
October 2016 JMP UG
On Oct. 17 we will hold are next JMP UG in Franklin TN at Mars Petcare from 1:30 p.m. - 4:30 p.m.  If you are interested in presenting, please respond.  If there is a topic you would like to see covered, please reply as well.  Currently we have one presentation / learning session on JMP scripting.
1 REPLY 1
ddelgad5
Reviewer
Re: October 2016 JMP UG
I will be there
David Delgado
