This website uses Cookies. Click Accept to agree to our website's cookie use as described in our Privacy Policy. Click Preferences to customize your cookie settings.
Practice JMP using these webinar videos and resources. We hold live Mastering JMP Zoom webinars with Q&A most Fridays at 2 pm US Eastern Time. See the list and register. Local-language live Zoom webinars occur in the UK, Western Europe and Asia. See your country jmp.com/mastering site.
Created:
Oct 3, 2022 01:51 PM
| Last Modified: Oct 24, 2023 01:44 PM
Prediction Profiler - Mastering JMP 20220930.jrn
The JMP Prediction Profiler is an option available from over 20 places in JMP to use DOE, observational and formula data to visualize and explore models and make decisions.
See how to:
Interpret the profile trace that shows each combination of X and Y variables and the black lines show how the predicted Y changes as X changes
Understand how the X axis shows factor, input variable, X column, independent variable, term and process parameter
Understand how the Y axis shows response, output variable, Y column, dependent variable and outcome
Examine the 95% Confidence Interval for Predicted Values
For continuous X variables you see a blue line and shaded area
For categorical X variables you see height of error bar
Examine current values of X as a vertical dotted line and red text on x axis
Examine predicted Y for current values of X as the horizontal dotted line and red text on Y axis
Examine 95% CI for predicted Y as the blue text on Y axis
ID important model factors that are important (steepness)
ID effects are significant (main, quadratic, interaction)
Optimize Desirabilities and ID combination of factor settings that will optimize the response
Define desirabilities
Remember settings
Lock factor settings (reset factor settings
Handle multiple responses
Simultaneously optimize responses
Handle response that is more important than the others
Q: What does decrease in desirability indicate? Does it mean that it's harder for us to meet the conditions specified in the profiler?
A: A decrease in desirability means that the current settings for the factors do not perfectly meet the desired outcomes set by the user. That perfect condition may not actually be possible, so desirability is more of a qualitative measurement.
Q: If I maximize desirability for %FPY or another response that is in %age, how do I limit the maximize desirability without going over 100% or under 0%? Would it just be match target?
A: You would need to use a transform on y or change the distribution that the model is using. An applicable transform on y might be Logit Percent or Logistic Percent.
Q: Is JMP making an estimate for the standard deviation for the simulation factors based on the data? I know you can type in your SD from production data.
A: Yes, that’s the starting point and you can tweak that manually, as well.
Q: Can you explain the 'Assess variable importance' option under the red triangle, and the different alternatives under this option?
A: Assess variable importance, at a high level, does exactly what it says - help you determine important variables. The details are documented here.
Q: Could I use desirability if I want to push the variable closer to LSL? For example, in manufacturing we want to push product specs closer to min spec to gain more volume which is more profitable.
A: You’d set the desirability to “minimize” and then set the lower limit in the desirability to match your spec limit.
Q: Can you copy a predicted formula from one file to another?
A: Yes, using the Formula Depot in JMP Pro. You can use a right click option on a formula column under Edit and then select Copy Column Properties, and from there go into another data table and right click and select Paste Column Properties. (this will bring over the column formula as well as any other properties in the Column).
Q: What is an interaction?
A: An interaction would be the combined effect of two factors. Mathematically it would show up as “Factor A * Factor B” as a term in the model. In words, an interaction describes to what degree Factor A depends on the level of Factor B in relation to the Y response, or alternatively and equivalently, to what degree does Factor B depend on the level of Factor A in relation to Y.
Q: Can you constrain factors to a certain range instead of locking them?
A: Yes, you can Add Linear Constraints. If your data is from a designed experiment where you defined the constraints for your design, the constraints from the DOE will automatically be applied.
Drag Linear Constraints
Add Constraint Values
Q: Sometimes you get yield over 100% with normal distribution. How can this be avoided so that the Prediction Profiler does not give you a non-physical value?
A: The JMP Pro Generalized Regression modeling capability avoids that by allowing you to change the distribution of your response that would bound it to between 0 and 1, for example.
Q: If someone wanted to push a variable closer to the lower spec limit, how would they do that using variables.
A: You can drag the upper and lower spec limits from within the Prediction Profiler or manually change by Alt/Click on PC within the Prediction Profiler Desirability area, get a pop-up and manually change values and desirability there.
Great presentation, thank you to my JMP colleagues!
Appearance > Adapt Y Axis is an especially useful option in the Prediction Profiler when exploring different settings and trying to keep everything visible all at once on each of the individual graphs.
I'd also like to add the following video reference for those interested in further reviewing and at times expanding on the content presented herein:
