New to using JMP? Hit the ground running with the Early User Edition of Discovery Summit. Register now, free of charge.
Practice JMP using these webinar videos and resources. We hold live Mastering JMP Zoom webinars with Q&A most Fridays at 2 pm US Eastern Time. See the list and register. Local-language live Zoom webinars occur in the UK, Western Europe and Asia. See your country jmp.com/mastering site.
Developer Tutorial: Using JMP to Create Orthogonal Mixed-level Screening Designs
Orthogonal Mixed-level Screening Designs introduced in JMP 18 are useful for JMP DOE users who need to test the effectiveness of many interventions simultaneously in a single experiment with minimal runs. See how to use JMP 18 orthogonal mixed-level screening designs to mix continuous and two-level categorical factors and use special constructions for mixed-level screening designs where continuous factors have some levels at the center. The three-level factors must be continuous, and the two-level factors can be either continuous or categorical. Additionally, these designs supply substantial bias protection of the main effects estimates due to active two-factor interactions.
The video includes a discussion with Tom Donnelly  @tom_donnelly  (~ time 49:24) about JMP design choices related to orthogonal mixed-level designs.  Tom's slides are included in the attachments to this video post.
See how to:
  • Find the designs in JMP using DOE->Classical->Factor Screening->Screening Design path
  • Understand the motivation for Orthogonal Mixed-Leve Designs
    • Main effects screening primary goal
    • Mix of three-level and two-level factors
    • Three-level factors are continuous (we’re not looking for balance)
    • Almost as many factors as runs (saturated, main effects screening), to 3/4 run size
    • DSD-like, but with more 2-level factors
  • Understand and view demo of Method/Option 3, where n is a multiple of 16
  • Understand and view demo of Method/Option 2, where n is a multiple of 8
  • Understand and view demo of Method/Option 1, where n is a multiple of 2
  • Delve into issues
    • Screening important factors, DSD too expensive, not all 3-levels
    • Detecting LARGE quadratics
    • Determining how much to go after quadratics
Resources
