Have your say in shaping JMP's future by participating in the new JMP Wish List Prioritization Survey
Practice JMP using these webinar videos and resources. We hold live Mastering JMP Zoom webinars with Q&A most Fridays at 2 pm US Eastern Time. See the list and register. Local-language live Zoom webinars occur in the UK, Western Europe and Asia. See your country jmp.com/mastering site.
Developer Tutorial: New Python Integration and Scripting Capabilities in JMP 18
This video includes Q&A from attendees who attended the live webinar on March 21, 2024. at time 25:36- 50:39 and 01:00:21  A summary of some of the Q&A is provided below.  For a full answer, consider reviewing the Q&A in the video.
Q: Can you send me what the GAPs are from JMP 16 to 18.
A: See the full release notes and version update notes.
Q: If python 3.11 is the default version, what about using libraries that rely on older versions of python?  Will there be some level of backwards compatibility with no guarantee of script running?
A: It will depend on what you can get from package repositories for 3.11.  If they work across versions. ,they may not run  or you may get message ‘package not found.’  Some packages require compilation and you must compile in a development environment on your system and in a few cases you have to install a standard 3.11 installation.
Q: I want to ensure that this is doesn't require Anaconda/Miniconda/Conda due to the cost and license requirement of these platforms.
A: These are NOT required.
Q: Can package installation be redirect to a controlled repository?  We cannot install directly from pypi.org without auditing them first.  I wasn't clear from your description if we could, for instance, create a venv, do package installation and then run that script in JMP's script editor.
A: No, we do not support venv and our environment is very close to that.  Most redirected packages require carefully changing vars in the jpip wrapper.
Q: Is possible to read the Python JMP environment and know how many packages you have installed?  as a user would like to keep track of packages version.
A: pip will give you the list of packages installed.
Q: Is there any tab level dependency to the python code in this environment?
A: The editor follows Python conventions.  Reformat is not enabled.  We will look at this for future release.
Q: Can I bundle python packages for my enterprise installation of JMP so my end user does not need to install libraries? For example, if I wanted to do a Python statistical analysis currently not in JMP (like Paul showed) can I publish that analysis report to JMP Live for my org to view and interact with.
A: If you can get your output into a JMP report you can publish it.  At present JMP Live does not support Python scripts running on the server but there are some security concerns that require more research to assure we don't compromise security.
Q: Does this mean JMP can't use other versions of Python? On the whole, if that's the tradeoff to having all the environment stuff handled so nicely, I think it's probably great, but just wondering.
A: Yes, you can use Python in JMP and then save to your external process and operate on the saved file. Python.org supports a Python version for only 5 years, so we chose this version to try to give us a full JMP 18-month cycle for users to use this.  We will switch to later versions later to give users a full 5 years if possible. To clarify:
JMP 18 will only utilize the installed embedded Python 3.11.  Python Init() and Python Connect() parameters for selecting a Python installation have all been deprecated and the parameters ignored.
JMP 18's Python is an isolated environment so it will not (should not) conflict with other Python installations on your system.  There is nothing that prevents you from utilizing your existing Python pipeline.  You can use JMP's Python to get data to and from JMP to hand off to your existing pipeline.
Q: Today as user i create Add-ins in JSL. Can i with JMP 18  create add-ins that combine JSL and Python as I see best fit?
A: Yes ,with the caveat that the add-in builder does not recognize Python files yet but you can edit the zip file and you can add the python file and JMP can run it.
Q: If I want to access a JMP data table from jupyter notebook in a different Python environment, would the 'import ‘JMP' instruction still work?
A: No.
Resources
Comments
I want to clarify the response to the question:
hogi
A: No.
How about "same Python environment" - is it possible to link python IDEs like Spyder or Visual Studio Code Editors  to the JMP Python installation?
To have all the Python programming functionality of the IDEs + the possibility to
import 'JMP'
The import jmp statement will only function from within JMP itself.
It is not implemented as a shared library or Python script, the bridge from Python to JMP functionality is C++ code internal to the JMP executable itself.
hogi
When sending tables with images to Python, is it possible to access the images from within Python?
# getColImage.py
# Description:
#   Get a picture from an image column using Python
#   JMP 18 only supports numeric and character column types for transfer
#   but the value can be grabbed via JSL, and passed to Python as a string
#   in the meantime.  The Python code will need to trim off the
#   New Image( Char To Blob()) and decode the image back to binary.
import jmp
dt = jmp.open(jmp.SAMPLE_DATA + 'Big Class Families.jmp')
jmp.run_jsl('''
Names Default to Here(1);
dt = Current Data Table();
img = dt:picture[1];		// get the picture
img_str = char(img);		// make it a string
Python Send(img_str);		// send Python the string
# print the object's JSL representation
# which is text encoding of the binary, a description of the
# encoding and image format type.
print(img_str)
With output:
New Image(Char To Blob( "1iVBORw0KGgoAAAANSUhEUgAAAEYAAABGCAYAAABxLuK   ...
VORK5CYII=", "base64compressed" ), "png")
From the Python side you need to parse out the Blob string, compression method, and format, decode the image from text to binary.
However, an alternate and likely better way is to use << Get Pixels("rgba"); on the column to get a 4 element list of matrices which is supported via Python Send().
Updated getColImage.py
# getColImage.py
# Description:
#   Alternatively use << Get Pixels("rgba");  to get a list of matricies
#   which is passable from JSL to Python using Python Send();
import jmp
jmp.run_jsl('''
asRGBA = { r, g, b, a} = dt:picture[1] << Get Pixels("rgba");
Python Send(asRGBA);
print(img_str)
print(asRGBA)
Somewhere the first few lines of the post got clipped.
No, not directly possible using the Python Integration in JMP 18, but a work around is possible using JSL.
The focus on JMP 18 was character and numeric columns.  Full support of the data table is current ongoing development.
