Have your say in shaping JMP's future by participating in the new JMP Wish List Prioritization Survey
Practice JMP using these webinar videos and resources. We hold live Mastering JMP Zoom webinars with Q&A most Fridays at 2 pm US Eastern Time. See the list and register. Local-language live Zoom webinars occur in the UK, Western Europe and Asia. See your country jmp.com/mastering site.
Developer Tutorial - Handling Covariates Effectively when Designing Experiments
  • What is a Covariate?
    • Input variable(s) we want to account for, but don't have complete control.
    • Uncontrolled, but observable ahead of time.
    • "Candidate Set" approach.
  • Why does it matter to Custom Design?
    • Coordinate-Exchange (Custom Design)
      • Start with a "random" design.
      • Go through design element-by-element, make a switch if it improves criterion.
      • Repeat.
      • No requirement for a candidate set.
    • Row-Exchange
      • PROC OPTEX (SAS)
      • Start with a candidate set of possible runs.
      • Initial design is a subset of the candidate set.
      • Consider swapping rows not in the design, making the switch if it improves criterion.
  • Prior to JMP 16 (starting with JMP 10)
    • Row-exchange on the covariates (D-optimality).
    • Coordinate-exchange on the controllable factors.
    • Covariates were fixed from the beginning and we couldn't go back to see if there's something better.
  • JMP 16
    • Hybrid approach with row-exchange or coordinate-exchange as we go through the design.
    • Allows for different optimality criteria to be considered for the covariates.
    • More flexibility for your design creation (best of both worlds).
    • Much more visible to the user.
    • How to use
      • Does not require JMP Pro.
      • Need a data table with candidate set (covariates with our possible runs).
      • Add covariates in Custom Design using Add Factor->Covariate (JMP 10+) or the "Covariates/Candidate Set" outline (JMP 16+).
  • Two typical use cases
    • Using all rows
      • We have observable, uncontrollable factors for our experimental units that we want to account for.
      • We want to force a particular structure for a subset of inputs (that may even be controllable).
    • Choosing a subset of rows
      • Pick an optimal subset (NOT a random subset).
      • Maximizing our information for our budget.
  • Example 1 - Using all Rows
    • We want 12 runs, 5 2-level factors, but factor A needs 2/3 of the levels at "L1" and 1/3 at "L2".
  • Example 2 - Using all Rows
    • Use Big Class data set, want to assign one of 2 treatments to each student.
    • We want to account for gender, height, and weight.
  • Example 3 - Using all Rows
    • Blocks of size 4, an 8-level categorical, and 4 continuous factors.
    • 56 runs total.
    • Use a balanced incomplete block design (BIBD) to start.
  • Example 4 - Using subset of Rows
    • Only want to pick 20 students from Big Class.
    • What about if there are certain students we want to ensure are chosen?
    • Add the batch label, but remove it from the model
Resources
Comments
H2OSUP
@Ryan_Lekivetz
Good morning Ryan,
I am designing an experiment with covariates. I would like to specify three of the batches to use in the DOE and let the software choose the rest. I thought this could be done in previous versions but do not see how to do it in my current version (JMP Pro 16.2.0). Can this be done? Thanks.
Mike
Hello Mike @H2OSUP ,
If you select those 3 batches from the table in Custom Design (or have only the 3 selected in the data table when you load the covariates), checking the "Include all selected covariate rows in the designs" should do what you want:
Cheers,
Ryan
