Register
for our Discovery Summit 2024 conference, Oct. 21-24, where you’ll learn, connect, and be inspired.
Practice JMP using these webinar videos and resources. We hold live Mastering JMP Zoom webinars with Q&A most Fridays at 2 pm US Eastern Time. See the list and register. Local-language live Zoom webinars occur in the UK, Western Europe and Asia. See your country jmp.com/mastering site.
I am designing an experiment with covariates. I would like to specify three of the batches to use in the DOE and let the software choose the rest. I thought this could be done in previous versions but do not see how to do it in my current version (JMP Pro 16.2.0). Can this be done? Thanks.
If you select those 3 batches from the table in Custom Design (or have only the 3 selected in the data table when you load the covariates), checking the "Include all selected covariate rows in the designs" should do what you want:
Cheers, Ryan
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '430161' && "TkbArticlePage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if (newSub.getAttribute("slang").toLowerCase() == code_l.toLowerCase()) {
if (value == '430161') {
else{
} else {
sub_L = newSub.innerHTML;
try{
catch(e){
if ("TkbArticlePage" == "IdeaPage") {
if ("TkbArticlePage" == "TkbArticlePage") {
if(subTkbElement){
else if ("TkbArticlePage" == "BlogArticlePage") {
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
