Learning Resources
Add-In Builder
(view in My Videos)
Use a JMP® Add-In to create custom menus and easily distribute JMP scripts, applications, data tables and more.
Create an Add-In with the Add-In Builder
  1. Choose File > New > Add-In (or File > New > New Add-In on the Mac).
  2. In the General Information tab, provide an Add-in Name and an Add-in ID.
  3. In the Menu Items tab, for each menu item:annotated.pngannotated.png
  • Click Add Command to add the menu item  and provide a menu item name ‚.
  • Browse for the JSL script the menu item will run.  Or, copy and paste the script next to Run this JSL ƒ.
  • Click Add Submenu (if needed) and provide a name to group items below a single heading, or Add Separator to add a separating line.
  1. If desired, use the Start-Up Script, Exit Script, or Additional Files tabs to add other scripts, graphics or data tables to the add-in.
  2. Click Save.  Edit the file name if desired (the Add-in ID will default, with a .jmpaddin extension), and click Save.
By default, the add-in will automatically install under the Add-in menu in JMP when saved.  Test the menu items to ensure that everything works as intended, and fine-tune as needed. The Add-in Builder will stay open until you close it, and saved changes will override the previously installed version of the add-in.
Share the add-in with other users.  When the file is opened in JMP, all files are extracted into the appropriate folder, and the add-in is installed in the JMP Add-in menu.
Tips and Limitations
  • julian_3-1593722103956.pngjulian_3-1593722103956.pngTo disable (remove from menu) or unregister (uninstall) an add-in, use View > Add-Ins.
  • To edit an add-in use File > Open, then click the arrow next to Open and select Open Using Add-In Builder (on Mac, first click “Options” then check “Edit after opening”).
  • To save an application as an add-in, select Script > Save Script to Add-In from the Application Builder red triangle (saving an application as an add-in requires JMP 10 or higher).
Note:  For more information on developing and deploying add-ins, search for Add-Inin the JMP Help or in the JMP Scripting Guide (under Help > Books). Explore jmp.com/addins for available add-ins.
Comments
hogi
Use a JMP® Add-In to create custom menus ...
Is it possible to create new menus - instead of submenus in the Add-In menu?
jules
Hi @hogi,
It is, but not using the Add-In Builder built into JMP. Your options are to manually edit the .jmpcust file that is part of the Add-In (it's xml), or to use @Justin_Chilton's really niceAdd-In Manager to build and manage you Add-Ins. This manager includes a number of additional customization options, including placing your menu items within existing menus, or creating a new menu entirely. Justin has a nice blog that discusses that particular use of the Add-In manger:
Add-In Manager, Part 3: Advanced customization
