Learning Library
Randomization Testing
This guide provides instructions on performing a randomization test (also known as a permutation test) – a resampling method for estimating the sampling distribution of a statistic to generate a confidence interval and a p-value for a hypothesis test. Randomization Testing is available from many JMP reports.
Here, we describe how to conduct a randomization test for two means using Fit Y by X.
  1. From an open JMP data table, right-click on the column header for the Nominal X variable (in this example, sex) and select New Formula Column > Random > Sample With Replacement. This creates a new formula column, Resample[sex].
  2. Conduct a 2-Sample t-Test using the Fit Y by X platform. For this example, the Y, Response is Weight and the X, Factor is sex.  See the page: Two Sample t-Tests and CIs for information on how to conduct this test and interpret results.
  3. In the analysis report window, right-click over the statistic of interest and select Simulate.  Here we right-click on the column of output containing the Difference (between means).
  4. In the Simulation window, select the column to switch out (sex) and the column to switch in (Resample[sex]), enter the desired number of samples (1000, in this example), and the random seed (if desired), and click OK.
  • JMP re-runs the analysis for each sample. For each iteration, the values of the X, Factor (sex) are resampled with replacement.
  • The results are stored in a data table with statistics for the original sample and each of the resamples. The SimID• column identifies the resample number.
  1. Use the Distribution platform to explore the results for the statistics of interest. Confidence intervals for the original estimate (the Difference, in this example) are provided, along with empirical (observed) p-values.
Interpretation:  The empirical p-value for the two-tailed test is 0.3530.  That is, 35.3% of the observed resampled differences were as extreme or more extreme than the difference we actually observed (7.37).
Big Class.jmp (Help > Sample Data Library)Big Class.jmp (Help > Sample Data Library)
The Randomization Testing Add-in available in the JMP User Community (community.jmp.com) provides a tool to perform randomization tests for common hypothesis tests in JMP.
Visit Basic Analysis > Simulate in JMP Help to learn more.
