Learning Library
Creating Formulas in JMP
This guide describes how to use formulas to create new variables (e.g, transformations, functions of existing
variables, perform logic operations, create patterned and random data, among others).
Method 1 (Create Formula With Formula Editor)
  1. From an open JMP data table, select Cols > New Column.
  2. Under Column Name, assign a name for the column. In this example, we name the column %profit/sales
  3. Click Column Properties, and select Formula. This takes you to the JMP Formula Editor (shown at right).
  4. To create this formula, we take the ratio and multiply by 100.
  • Select Profits ($M) from the Columns list.
  • Click on the divide by symbol on the keypad.
  • Select on Sales ($) from the Columns list.
  • Click on the outer gray box (surrounding the ratio).
  • Click on the multiply symbol on the keypad.
  • Type “100” on your keyboard, and click OK. This populates the data table column with the calculated % Profit ($M)/Sales ($M) for each observation.
Example: Companies.jmp (Help > Sample Data Folder)Example: Companies.jmp (Help > Sample Data Folder)
Method 2 (Create New Formula Columns from an Existing Column(s))
1. From an open JMP data table, right-click on a column and choose New Formula Column. Choose from a list of functions. The new column along with the formula will be saved to the data table.
Note: If multiple columns are highlighted, a set of Aggregate formulas will be made available (e.g, mean, sum).
Choose forumla functions when creating a new formula column from an existing columnChoose forumla functions when creating a new formula column from an existing column
Method 3 (Temporary Columns)
  1. From a launch window (e.g., Fit Y by X), right-click on a column inthe columns list. Choose desired formula. This temporary column (available just within that current platform) can be used.
Note: To save that temporary column to the data table, right-click on the temporary column that was created and select Add to Data Table. This adds a new column and creates the formula, which is accessible through the Formula Editor.
Note: To access the Formula Editor for any formula column, right-click on the column name and select Formula.
Create temporary column and add to data tableCreate temporary column and add to data table
Visit Using JMP > Create Formulas in JMP in JMP Help to learn more.
