Learning Center
Videos, activities, learning paths, and articles to help you learn and grow your curiosity about JMP. From novice to advanced JMP users, the Learning Library has content for everyone.
How can I create and save customized interactive drill-down graphs in JMP?
In JMP,  you can add a thumbnail of a graph or an image of  elements on a  graph built using Graph Builder.  These thumbnail, customized, interactive graphs are called graphlets.  You can also nest graphlets.
Start by creating a graph in Graph Builder.  This is your baseline graph. Copy the script by saving it to your clipboard using SAVE SCRIPT > TO CLIPBOARD,  and then paste it as a graphlet into a baseline graph.  After you have added the graphlet, you can put your cursor over an element in the baseline graph to see a thumbnail preview of the graphlet for that element.
To nest graphlets, copy them starting from the lowest level into your clipboard using SAVE SCRIPT > TO CLIPBOARD, then paste into the next highest-level graph, until you have the final graph.   Then,  save the final graph using SAVE SCRIPT > TO DATA TABLE.  Remember to then save the table.  When you open the table, you can run the script from the Tables Panel, see the highest-level graph and drill sequentially into the lower-level graphs.
See a short example that also includes adding and saving a data filter.
See a full Mastering JMP video on how to create custom drill-down graphs.  Work through documentation and examples about creating graphlets and other customizable hover graphs.
Comments
Hover Labels made easy!
Great video!
