Check out the JMP® Marketplace featured Capability Explorer add-in
Design of Experiments Introduction Kit
Comments
GinaBecker
@ryandewitt Unfortunately, the example tables don't match the video data, and there is no way to know what values for Flight Time to enter for my data to get the correct results to answer the test question.
This has been the case with other examples--none of the experiment designs have matched the video design, even though the seeds and starts were entered correctly--but there was always a file in the samples to copy into the design, which gave the right answer.  I can't find the file for the helicopter data to copy.  Guess I'm stuck and can't proceed.  ;-(
@GinaBecker if you use the @ function, the person will get your comment immediately.  I added @ryandewitt to your comment above for you.  Gail
KimRas2
@gail_massari @ryandewitt
Was the issue mentioned above sorted out now?
