Better JSL Smoother Migration: How To Fix Your Own Code​
Learn how to build robust JSL scripts that can also make migrations to new versions of JMP and JMP Pro more efficient. Learn about how to increase efficiency creating scripts and how to use the embbedded and enhanced logs according to your needs.
Windows demo:
Here is another talk by JMP Developers @Wendy_Murphrey and  @Justin_Chilton on this topic:
Comments
Raaed
good job
compact + many tricks -> very helpful!
With JMP18,
got easier - and robust against issues with upper/lower case, spaces , ...:
https://community.jmp.com/t5/JMP-Wish-List/data-table-message-column-exists-colname/idc-p/597068/hig...
dt << has column("times")
