Learn JMP Events
Events designed to further your knowledge and exploration of JMP.
Using MSA for Situations Requiring Destructive Testing
Presented in English
Published on ‎11-07-2024 03:30 PM by Staff | Updated on ‎11-07-2024 05:40 PM
See how to:
  • Address key assumptions for MSA (Parts do not change form over time and are not changed by measuring them)
  • Overcome inability to repeat measurements when key MSA assumptions are violated
  • Perform and interpret desctructive test that assumes perfect material and likely overestimates part-to-part variation
    • Assume material within a lot or a batch is uniform
    • Gather multiple lots where each lot represents a part
    • Subdivide lots so that each subdivision will represent a repeat measurement when tested
    • Test all parts in a random order.
    • Analyze using EMP method.
  • Perform and interpret desctuctive test that assumes perfect test and likely underestimates part-to-part variation
    • Use a nondestructive test that correlates well with the destructive test
    • Build a calibration curve from destructive and nondestructive test data
    • Test parts nondestructively in a random order
    • Test parts destructively in a random order
    • Use the formula from the calibration curve to scale the nondestructive data
    • Combine results
    • Analyze using the EMP method
Notes: Questions are included at the end of the demo, beginning at ~ Time 32:30.
Resources
A reminder that to contact Jason Wiggins in comments, include @Jason_Wiggins. in your comment. Measurement Systems Analysis.zip is a zipped version of Jason's JMP 16 Project used in the session.
Start:
Fri, Aug 13, 2021 02:00 PM EDT
End:
Fri, Aug 13, 2021 03:00 PM EDT
1 Comment
PatrickGiuliano
Here is another valid link that you can use to access the publication referenced in the presentation:
De Mast, J. and Trip, A. (2005). Gauge R&R Studies for Destructive Measurements. Journal of Quality Technology, 37(1), 40-49
https://www.vitalentusa.com/links/pdfs/Gage_RR_Destructive%20Measurement.pdf
