Learn JMP Events
Events designed to further your knowledge and exploration of JMP.
Using Blocking When Designing Experiments
Published on ‎11-07-2024 03:28 PM by Community Manager Community Manager | Updated on ‎11-07-2024 05:38 PM
See how to:
  • Understand the restrictions associated with randomization, the difference between blocking and creating plots, and how to incorporate covariates into the design (1:26)
    • Blocks are about variance and let you group homogeneous factors to isolate extraneous noise associated with the factors (like time of day)
    • Plots address variability and let you organize units so you can estimate the noise/signal associated with factors
    • Incorporating covariates (uncontrolled factors related to the experiment and known before the experiment) lets you asses the impact of the related factors
  • Understand the factors related to the widget case study where manufacturers add hardening agent to slurry, stir it, control viscosity, mold it and then bake it (7:06)
  • Use Custom Designer to incorporate differences related to differences related to the day the experiment runs (8:55)
    • See how to group runs into blocks to estimate variability from day to day (Random Effect blocks)
    • See how to add Blocking Factor to calculate mean differences from day to day (Fixed Effect blocks)
    • Understand the impact of choosing Random vs. Fixed Effects on the number of runs needed for the design.
    • Understand why to choose a Split-Plot design to get estimates of signal plus noise
  • Use Custom Designer to build Split-Plot design that includes statistics related to interactions between hard-to-change and all other factors (18:28)
  • Compare incorrect and correct designs (27:00)
    • Examine Fixed Effect Test results
  • Understand and compare Split-Split-Plot and two-way Split-Plot (Strip Plot) Designs (30:16)
  • Add information about a related factor (covariate) to the model (38:43)
    • Handle mis-match between number of covariate observations and number of runs needed
Note: Includes Q& A at times 36:30, 43:53. 44:49 and 45:16.
Resources
Start:
Thu, Jul 9, 2020 02:00 PM EDT
End:
Thu, Jul 9, 2020 03:00 PM EDT
Labels (1)
0 Comments
