The Discovery Summit 2025 Call for Content is open! Submit an abstract today to present at our premier analytics conference.
See how to use to use Text Explorer to glean valuable information from text data at April 25 webinar.
View Original Published Thread
Design Diagnostics
Published on ‎11-07-2024 03:29 PM by Community Manager Community Manager | Updated on ‎11-07-2024 05:38 PM
See how to:
  • Determine which designed experiment for a product, process, or behavior is most suitable for your needs based on what can be estimated, how precise the estimations are and the effect of leaving things out of the model
  • Build and compare a Custom Design, Definitive Screening Design and an augmented Plackett-Burman-like Design for a product with two categorical and seven continuous factors
See how to:
  • Compare three different designs
    • Us epower analysis to help determine which factors might be identified as useful for determining the probability of detecting a real signal
    • Identify which portion of the design space is below a certain variance
    • Plot the prediction variance surface as a function of the design factors
  • Choose the most appropriate design
0 Comments
