  • See how to create experiments to support product design and ID useful product features. Register for June 12 webinar, 2pm US Eastern Time.
Learn JMP Events
Events designed to further your knowledge and exploration of JMP.
Developer Tutorial: Bayesian Optimization
Presented in English
Published on ‎08-18-2025 08:48 AM by Community Manager Community Manager | Updated on ‎11-24-2025 09:36 AM
Video using JMP Pro 19 was posted in November 2025.
This session is for R&D product and process engineers responsible for innovating quickly to be the first to market with a new product.
Bayesian optimization is an iterative learning technique that uses a model to generate new candidate runs for assessment. Bayesian optimization learns from the responses with each iteration and gives us clearer guidance than traditional approaches about when we can stop experimenting. The iterative nature has the potential to dramatically reduce the time and resources required for process and product development, so may be a natural fit for many R&D cultures.
Starting with existing data, either historical or from an initial set of experimental runs, a Gaussian Process model (GaSP) is constructed. Then, using the model predictions, along with the prediction uncertainty and the response goals, new candidate factor combinations are generated to test. After test, the model is updated with the new data. This sequence of steps repeats until the response goals are met and an optimal combination of factor settings is discovered.
New enhancement to JMP Pro incorporate an interactive new platform, Bayesian Optimization.
"This technique is not for determining how well the model fits. Rather, it is a way to discover new regions to explore where we don't have data yet." C. Gotwalt
JMP Chief Data Scientist and a key Developer of the new Bayesian Optimization, Chris Gotwalt, demonstrates and explains the capability and the underlying statistical approaches it deploys. The session includes time for Q&A.
This JMP Developer Tutorial covers: interactively generating the initial Gaussian Process model; specifying new candidate factor combinations to test or run; exploring design space; summarize Gaussian Process model fit; comparing and interactively doing what-if analyses on factors and responses.
Resources
Featured Guests
Start:
Fri, Oct 31, 2025 02:00 PM EDT
End:
Fri, Oct 31, 2025 03:00 PM EDT
Labels (1)
0 Comments
