Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
With JMP Discovery Summit in Brussels right around the corner, I decided to put some shape files for Belgium on the File Exchange. There are shape files for the Belgium Provinces and for the cities of Belgium. I hope you find these useful.
Last Modified: Mar 12, 2015 4:50 PM
