JSL Cookbook - Archived
Building blocks of JSL code to reduce your coding workload.
Geographic Maps with Graphs as Markers
Problem
Create a geographic map with "graphlets" positioned over associated map locations.
Solution
Context is everything! So just as one might want to embed tiny line charts in a text block as sparklines to show them in the context of a discussion, someone might want to embed tiny bar charts in a map to compare variables in the context of their location. Someone like our own @scwise, who added this suggestion in a wish list entry.
The solution can be implemented using two recent JMP features - virtual joins and the ability to use images in table cells as markers. Combined with the Graph Builder's ability to create a data table with graph elements from a composite graph, we have all the pieces needed to solve this puzzle. The final result looks like this:
US Elections 2008: Obama vs McCainUS Elections 2008: Obama vs McCain
Details below:
dt1 = Open("$SAMPLE_DATA/US Election 2008.jmp");
// Create per state graphs
gb1 = Graph Builder(
	Variables( Y( :Obama ), Y( :McCain, Position( 1 ) ), Page( :State ) ),
	Elements( Bar( Y( 1 ), Y( 2 ), Legend( 8 ), Summary Statistic( "Max" ) ) ),
		Dispatch(
			ScaleBox( 2 ),
			{Min( -0.657608695652174 ), Max( 0.657608695652174 ), Inc( 0.25 ),
			Minor Ticks( 0 )}
		Dispatch(
			ScaleBox( 3 ),
			Minor Ticks( 0 )}
		Dispatch( {}, "400", LegendBox, {Set Title( "" )} )
// Save graphs as images to data table
dt2 = gb1 << Make into Data Table;
// Tip: save table to enable virtual join
dt2 << Save("$TEMP/ElectionPerStateGraph.jmp");
// Set virtual join between tables
dt2:State << Set Property("Link ID", 1);
dt1:State << Set Property(
			"Link Reference",
			Reference Table( "$TEMP/ElectionPerStateGraph.jmp" ));
// Use virtually joined graph column as source for markers
col = Column(dt1, "Graph[State]");
col << UseForMarker( 1 );
// Create map with a points overlay using graph markers
dt1 << Graph Builder(
	Size( 534, 456 ),
	Show Control Panel( 0 ),
	Variables( Shape( :State ) ),
	Elements( Map Shapes( Legend( 2 ) ), Points( Legend( 3 ) ) )
JSL Cookbook
If you’re looking for a code snippet or design pattern that performs a common task for your JSL project, the JSL Cookbook is for you.
This knowledge base contains building blocks of JSL code that you can use to reduce the amount of coding you have to do yourself.
It's also a great place to learn from the experts how to use JSL in new ways, with best practices.
