Try the Materials Informatics Toolkit, which is designed to easily handle SMILES data. This and other helpful add-ins are available in the JMP® Marketplace
Select rows that match any value in a list
Problem
Suppose you prompt a user to make a selection. When you retrieve the values from the user, typically they are stored in a list.  Now you need to select the data that matches the values in the list.
Solution
The following example demonstrates how you can select rows in a data table that contain any value stored in a JSL list. Lists containing either numeric values or character strings can be used and are shown below.  See the embedded comments for details.
/* Open a sample data table. */
dt = Open( "$SAMPLE_DATA\Big Class.jmp" );
/* Create a list of ages. */
myList = {9, 12, 15, 17, 18};
/* Select all rows which have an age that is in the list. */
dt << Select Where( Contains( myList, :age ) );
Wait( 2 );           // For demonstration purposes
/* Create a list of student names. */
myStudents = {"HENRY", "ROBERT", "BARBARA", "SALLY", "MARION"};
/* Select all rows which have any of the names in the list. */
dt << Select Where( Contains( myStudents, :name ) );
Discussion
In these examples, the Contains() function is used to compare each row to the list of values.
Many more examples of using Select Where() can be found in the Select Rows section of the JMP Scripting Guide.
See Also
Select rows from the currently selected rows
Select rows based upon multiple conditions
Comments
hogi
dt << Select Where( Any( Row() == Index( 3, 5 ) ) );
is cool
is there something similar for
dt << Select Where( Any( :name == {"JANE", "DAVID","PATTY"}) );
jthi
Isn't that what you would use Contains() for?
hogi
same result, yes.
but different syntax.
jthi
Is there some specific need to use more complex syntax? You could use Loc with Any
Names Default To Here(1);
dt = Open("$SAMPLE_DATA\Big Class.jmp");
dt << Select Where(Any(Loc({"JANE", "DAVID", "PATTY"}, :name)));
hogi
Ah, nice
I feared that contains is slower. but actually ...
note to myself: use contains
View more...
Names Default To Here( 1 );
Try(close(dt, noSave));
results = New Table( "Untitled",
	Add Rows( 0 ),
	New Column( "rows" ),
	New Column( "t_contains_string" ),
	New Column( "t_any_loc_string" ),
	New Column( "t_contains_number" ),
	New Column( "t_any_loc_number" ),
	New Column( "t_any_number" )
dt << New Column( "nameID", Formula( Row() ) );
dt:nameID << delete formula;
For( i = 1, i <= 20, i++,
	t0 = HP Time();
	dt << Select Where( Contains( {"JANE", "DAVID", "PATTY"}, :name ) );
	t1 = ((HP Time() - t0) / 1000000);
	t0 = HP Time();
	dt << Select Where( Any( Loc( {"JANE", "DAVID", "PATTY"}, :name ) ) );
	t2 = ((HP Time() - t0) / 1000000);
	t0 = HP Time();
	dt << Select Where( Contains( {3, 15, 20}, :nameID ) );
	t3 = ((HP Time() - t0) / 1000000);
	t0 = HP Time();
	dt << Select Where( Any( Loc( [3 15 20], :nameID ) ) );
	t4 = ((HP Time() - t0) / 1000000);
	t0 = HP Time();
	dt << Select Where( Any( :nameID == [3 15 20] ) );
	t5 = ((HP Time() - t0) / 1000000);
	results << add rows( {:rows = N Rows( dt ),:t_contains_string = t1, :t_any_loc_string = t2, :t_contains_number = t3, :t_any_loc_number = t4, :t_any_number = t5} );
	dt = dt << concatenate( {dt}, Append to first table );
JSL Cookbook
If you’re looking for a code snippet or design pattern that performs a common task for your JSL project, the JSL Cookbook is for you.
This knowledge base contains building blocks of JSL code that you can use to reduce the amount of coding you have to do yourself.
It's also a great place to learn from the experts how to use JSL in new ways, with best practices.
