Problem
Problem 1: I need to get a list of the unique values in a data table column.
Problem 2: I need to get a list of the unique values in a JSL data structure (list or matrix)
Solution
For problem 1:
Solution 1: Use summary tables. The JSL below shows how to use Summary() to get a table that will have a row with each unique value in a single column. You can then do further JSL table commands to get those values from the summary table.
_dt = Open( "$sample_data/big class.jmp" );
//create a summary table of the :sex column
_dt1 = _dt << Summary(
Group( :sex ),
Freq( "None" ),
Weight( "None" )
//create a summary table of the :age column
_dt2 = _dt << Summary(
Group( :age ),
Freq( "None" ),
Weight( "None" )
Problem 2:
Now, instead of a data table you have a JMP list or matrix:
sexlist = {"F", "M", "M", "F", "F", "M", "M", "F", "M"};
agelist = [14, 11, 12, 13, 15, 17, 15, 11, 12];
the complicated ways to do this would be:
a) put the values in the list into a new data table column, and then use the summary approach, OR
b) write a somewhat complicated for loop to search for and record unique values
Fortunately, there is an easier way, using associative arrays.
Associative Array(sexlist) << Get Keys;
Associative Array(agelist) << Get Keys;
returns {"F", "M"} and {11, 12, 13, 14, 15, 17}, respectively (note that these are nice sorted list!). If you would like the numeric values as a sorted vector, you can use
Matrix(Associative Array(agelist) << Get Keys);
which returns [11, 12, 13, 14, 15, 17].
This approach can also be used in place of Solution 1 for Problem 1:
Problem1, Solution 2:Associative Array(Column(_dt, "sex") << Get Values) << Get Keys;
Matrix(Associative Array(Column(_dt, "age")<< Get Values)<<Get Keys);
returns {"F", "M"} and [11, 12, 13, 14, 15, 17]., respectively. What this is doing is
- get the values from the specified column as a list (if the column is character) or a matrix (if the column is numeric)
- turn that list or martrix into an associative array
- get the keys for the associative array, which in this case are the unique levels of the values in the column, returning that as a list
- (if Matrix() is used on the resulting list, it will only work if the values in the list are all numbers).
