JMPer Cable Blog
XanGregg
Quick eclipse path map
The 2017 US eclipse is just around the corner, and eclipse maps are everywhere. After hearing that the NASA eclipse site has coordinate data, I wondered how quickly I could make map of the eclipse path from scratch. Here is an animated GIF of the whole process.
I eyeballed the width of the totality path and checked it later against the full data. The bounds of totality and other coverage amounts are available in other downloaded files, but I wanted to keep this video simple.
A few nice JMP features illustrated here:
  • reading data from shapefiles (SHP)
  • applying a geodesic projection
  • adding both a background map image and background map shapes
Last Modified: Aug 18, 2017 1:25 PM
