Are you a JSL master? Take the JMP Certification exam on JSL.
Do you use JMP Scripting Language (JSL) in your job? Do you consider yourself to be a JSL master? If you want to test and show your skills using JSL, there's a new certification available. It's the new exam for JMP Scripting Language using JMP 14!
When you take the JMP certification exam, you access JMP to perform a variety of scripting and programming tasks using JSL.
Successful candidates are able to:
- Utilize all JSL elements to design and build a script, end-to-end.
- Identify required data sources and then import data from a variety of sources/platforms.
- Clean and transform data.
- Use messages, functions and expressions to create new data tables and columns, control analyses, and capture or modify reports.
- Create and use dialog boxes to adapt the behavior of a script.
- Create a custom report using New Window and display boxes.
- Perform programming concepts: looping, error handling, namespaces, including other scripts, data structures, name resolution, conditional logic.
- Build a script framework that allows for conducting the required analysis, reporting and visualization of data.
Complete information about this credential and exam is on the SAS US Certification website.
What questions do you have about this certification? Leave me a comment or question here. For general questions, you can email certification@sas.com.
