JMPer Cable Blog
AllisonHines
File Exchange transitioning to JMP Marketplace
Since its launch in October 2024, the JMP Marketplace has served as a central hub for secure, quality-controlled JMP extensions. To offer you the best possible experience, we're streamlining our platforms and phasing out the File Exchange.
Here are the key dates to remember:
  • July 7, 2025: The File Exchange will no longer accept new submissions.
  • End of 2025: The File Exchange will be removed permanently.
We encourage all users who want to share their JMP extensions to publish them directly to the JMP Marketplace. As long as your extension meets our guidelines, we'd love to see it there! Please note, JMP reserves the right to remove any content from the JMP Marketplace at our discretion.
How to submit your extension to the JMP Marketplace
Ready to share your innovative extensions with the JMP community? We've made the submission process straightforward. You can find comprehensive information on our guidelines and the JMP Marketplace validation process here.
To submit your extension, simply complete this form.
Here are the minimum requirements for submitting an extension:
  • The extension file as a .zip: This can include an add-in, journal, data connector, dataset, or other relevant files. If you're submitting a single .jsl file, we highly recommend consolidating it into an add-in.
  • At least one image: A screenshot illustrating the extension's interface is perfect.
  • Metadata information: This includes details like compatible hosts, JMP versions, and JMP product compatibility.
  • A clear description: Outline how to use your extension effectively.
If you have any questions about the JMP Marketplace submission process or testing, don't hesitate to reach out to us at [email protected].
Last Modified: Jun 26, 2025 7:54 PM
Comments
hogi
Level XIII
hi @AllisonHines , thank you for the advanced notice.
Does "File Exchange" refer to the AddIns subgroup or to all the data stored in AddIns, Scrips and SampleData ?
Ryan_Gilmore
Community Manager
@hogi Definitely the Add-in portion. There are very few submissions to the Scripts and Sample Data sections so I don't foresee their removal having much impact.
hogi
Level XIII
sounds good.
from point of view of the Marketplace, there is little difference between AddIns and the whole File Exchange.
From the File Exchange's point of view, it's a good idea to keep the /Scripts and Sample Data folders.
People can continue to share small snippets via the File Exchange without having to submit them to the Marketplace.
And for AddIns in the File Exchange, users can decide if it's worth to polish it for the marketplace - or to share it as a snippet.
hogi
Level XIII
another similar statement:
@Ryan_Gilmore , @AllisonHines , could you please confirm (again) that the File Exchange will stay beyond 2025 and submissions/downloads of files and scripts will still be possible in the future  - despite the announcement: "hogi_2-1762987245532.png". What does it mean: retire?
The recent hiccups with the new community re-design were significant and there are still several unsolved issues.
I fear that non-intended announced (!) changes will have an even larger impact.
Ryan_Gilmore
Community Manager
@hogi the content of the File Exchange will still be available in the Community via search but there will be no navigational links to access the content. Also, at this time, we will not be accepting further submissions to the File Exchange.
hogi
Level XIII
so, there is no place anymore where uses can submit template scripts or test data tables.
