  • See how to use JMP Pro to analyze and predict using entire data set rather than selected points in a curve. Register for Nov. 6 Mastering JMP.
JMPer Cable Blog
gail_massari
Expression Handling Functions: Part I - Unraveling the Expr(), NameExpr(), Eval(), ... Conundrum
This article originally appeared in JMPer Cable, Issue 26, Winter 2010
by Joseph Morgan joseph.morgan, JMP Senior Software Developer, SAS
Note: The JSL in this article is compatible with JMP 9 and later.  Accordingly, the code may not reflect the power of JSL introduced with versions of JMP released subsequent to JMP 9.
Introduction
Many beginning and intermediate JMP Scripting Language (JSL) programmers are unaware of the power of abstraction available from JSL expressions. Such meta-programming constructs are not always available in widely used programming languages such as C++ but are commonly found in functional programming languages such as Lisp.
As it turns out, such constructs are particularly useful when the application being developed is complex. They facilitate process abstraction. Robert Sebesta (1999) describes abstraction:
“The ability to define and then use complicated structures or operations in ways that allow many of the details to be ignored. The degree of abstraction allowed and the naturalness of its expression is important.”
This article attempts to unravel the mystery surrounding JSL expression handling functions and show how such functions can be used to solve nontrivial JSL programming challenges.
Concluding Comments
The primary purpose of these examples is to illustrate the use of several expression-handling functions. A secondary purpose is to point out common errors and misunderstandings that JSL programmers sometimes experience when attempting to use these functions. Hopefully, we have partly achieved that objective.
References
SAS Institute, Inc. (2008), JMP Scripting Guide, Cary, NC: SAS Institute, Inc.
Sebesta, Robert M. (1999), Concepts of Programming Languages, Addison Wesley, Reading, MA.
Last Modified: Nov 9, 2016 5:12 AM
Comments
