JMPer Cable Blog
JerryFish
A simple way to automate "File Import/Append/Cleaning/Generate Report"
Ever wanted to automate processes and analyses? You can do it in JMP! This video shows how to automate the following steps, with a minimal amount of JSL (JMP Scripting Language) coding:
  1. Create a file dialog to allow you to select and open a file
  2. Append that data to a "master data table"
  3. Clean the data (using stored Recode command)
  4. Generate a report from the updated Master Data Table
(view in My Videos)
Last Modified: Mar 20, 2020 9:20 AM
Comments
jntwist
Level II
Good video.  Thanks.  JT
Sebnem
Level II
Hello,
Can you make the script available?
rc_hertzy
Level III
// Script to concatenate a file to an existing master file
Names Default To Here( 1 );
// Open the master data table
// Then call current master data table "dtmaster"
dtmaster = Current Data Table();
// Open file dialog to select file to be appended to master, name it "dtnew"
// If an Excel file the Excel Import wizard will open
dtnew = Open();
//Concatenate the new to the master file by appending it
dtmaster << Concatenate( dtnew, Append to first table );
//Close new table
Close( dtnew, NoSave );
// Now the master file contains the new appended info
Bass_Masri
Level VI
Brilliant Jerry - Great tips for automation.
PatrickGiuliano
Thanks @JerryFish for preparing and posting this!  A nice bite sized guided video journey into automating a script with importing.
I'd like to share another nice reference here on data preparation and analysis in JMP since I think it is at least partially connected to what you have shared; It's a white paper available on jmp.com entitled: "JMP takes the struggle out of data wrangling."
Cheers,
