Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
@vince_faller interesting idea. We would like to understand better how a JMP user would or could use a YAML file in their work. Also, this seems like a really good candidate for a JMP Script/Addin to prototype and illustrate the value. Do you have something like that already?
My immediate use is piggybacking off my gitlab-ci.yml in order to grab the parameters of the pipeline. For long term stuff I'd say that lots of configs are in yml because it's basically a JSON that allows commenting with a more human readable format. Currently in JSL we only really have two options for configs that I know of but there are problems for both.
.jsl
This obviously isn't good for cross platform projects (Lots of my stuff is some python, some JSL)
.json
This doesn't allow for comments
When I was at predictum I looked at a bunch of configs and I'll give my opinionated view of the other options
ini
fine for simple configs, but gets messy when hierarchical configs start to happen
still doesn't allow comments
toml
allows comments,
better than ini for heirarchies but can still get messy
json
no comments
standard is great hierarchical structures
yaml
comments are allowed
hierarchical structures are human readable
anchors and aliases allow configs to be more DRY (admittedly this probably wouldn't be used much for 99% of JSL users)
jsl
Non-starter because other languages can't use it.
