yaml parser
For a lot of my python stuff configs are in .yml.
I'm currently using pyyaml to a dict and pulling it in that way but if it could read it directly, that'd be cool.
That being said, I understand that the yaml spec is a large undertaking.
3 Comments
SamGardner
Level VII
@vince_faller interesting idea.  We would like to understand better how a JMP user would or could use a YAML file in their work.  Also, this seems like a really good candidate for a JMP Script/Addin to prototype and illustrate the value.  Do you have something like that already?
SamGardner
Level VII
Status changed to: Not Planned For Now
vince_faller
Super User (Alumni)
My immediate use is piggybacking off my gitlab-ci.yml in order to grab the parameters of the pipeline.  For long term stuff I'd say that lots of configs are in yml because it's basically a JSON that allows commenting with a more human readable format. Currently in JSL we only really have two options for configs that I know of but there are problems for both.
  • .jsl
    • This obviously isn't good for cross platform projects  (Lots of my stuff is some python, some JSL)
  • .json
    • This doesn't allow for comments
When I was at predictum I looked at a bunch of configs and I'll give my opinionated view of the other options
  • ini
    • fine for simple configs, but gets messy when hierarchical configs start to happen
    • still doesn't allow comments
  • toml
    • allows comments,
    • better than ini for heirarchies but can still get messy
  • json
    • no comments
    • standard is great hierarchical structures
  • yaml
    • comments are allowed
    • hierarchical structures are human readable
    • anchors and aliases allow configs to be more DRY (admittedly this probably wouldn't be used much for 99% of JSL users)
  • jsl
    • Non-starter because other languages can't use it.
