version control
☑ cool new feature
☑ could help many users!
☑ can be used to remove bugs
☐ nice to have
☐ nobody needs it
JSL programming is a lot of fun. Via trial and error, it's easily to find the right expression - even if a detail is missing in the documentation.
To support the "trial and error" - a version control could help to keep track which version worked, which line was changed, which expression causes the new error.
Please add version control to JMP
- directly inside JMP
- with the possibility to run and test different versions of the code
- with the ability to compare different versions
- as an addition to an external "long time" version control
-> OK if it just tracks the versions since the last start of JMP (in memory)
Why is this idea important?
JSL programming will get much easier.
2 Comments
hogi
Level XII
Thanks for the update
I just noticed that with the help of JSL Scripting, one can create such a version control with a few lines of code:
