show properties in JSL
☐ cool new feature
☐ could help many users!
☐ removes a „bug“
☑ nice to have
☐ nobody needs it
The "Help Scripting Index" entry in the right click context menu is very helpful to open the scripting index info for a JSL object or function.
Is there also such a fast way to run "show properties" for a JSL object - perhaps with a possibility to select one property and use it directly in my code ( e.g. auto-send to clipboard to paste it at the correct position in the code)?
4 Comments
SamGardner
Level VII
Status changed to: New
@hogi , could you describe more what you are wanting to do?
If you use
Show Properties(object);
then in the log window all of the messages you can pass to the object are listed.
Are you simply wanting a "command picker", or something else?
hogi
Level XIII
Hi @SamGardner
Yes, like this. Starting from the
some additional functionality to save some steps:
- right click on an object to open the right click context menu
- click on the new "show properies" entry :)
- then a sub-menu opens (like the "Advanced" submenu) with all the properties
(or a new window with the properties list?)
- then choose one of the "properties"
- which sends the code to the clipboard
- and then you can directly pase the code wherever you want.
hogi
Level XIII
@Sarah-Sylvestre , @SamGardner :
2 years and 0 Kudos -> can be archived .
Sarah-Sylvestre
Level V
Status changed to: Archived
