JMP Wish List
saving list of cols created by text to column
Multiple file import and open functions are able to save a list of files they open in a list. I'd like to see something similar with functions that can generate multiple columns from one, mainly text to columns
saving text to column to a variable saves a list of column names generated to a list.
Example: A dt containing a column of numbers separated by commas
new_cols_list = dt << Text to Columns( columns( :Numbers column ), Delimiters( "," ) );
Why is this idea important?
This would allow more compact identification of generated columns, and therefore more streamlined, and less error-prone way of working with these columns, if needed
2 Comments
It is fairly easy to check which columns were created, but it would still be useful if Text To Columns did just return the list of just generated new columns (names/references or maybe work in similar manner as << Get Column Names where user can decide?). And if no columns are returned just return empty list
Example how newly created columns can be checked (similar method can be used during table or window creation too). The returned list will be ordered in alphabetical order due to usage of associative array
dt = Open("$SAMPLE_DATA/Consumer Preferences.jmp");
old_cols = Associative Array(dt << Get Column Names("String"));
dt << Text To Columns(
	delimiter(","),
	columns(:Brush Delimited),
	Make Indicator Columns(1)
new_cols = Associative Array(dt << Get Column Names("String"));
new_cols << Remove(old_cols);
new_cols_list = new_cols << get keys;
StarfruitBob
I was doing something very similar to what you describe, but thought "there must be a simpler" way"!
