report/save script: add semicolon
☐ cool new feature
☑ could help many users!
☑ removes a „bug“
☐ nice to have
☐ nobody needs it
When scripts are copied to the Scripting Window via the save script command in the red-triangle menu, there is a Semicolon added at the end of the script to glue them together.
When the scripts are saved to the data table or copied to the clipboard, no Semicolon is added.
Mi wish: please let JMP add the Semicolon independent of the case.
Then the scripts can be concatenated manually without taking care if the glue operator is missing.
8 Comments
Hi @hogi, thank you for your suggestion! We have captured your request and will take it under consideration.
mia_stephens
hogi
Level XIII
thanks a lot!
a tiny little change in Jmp - but a huge improvement for the users - especially the newbies
hogi
Level XIII
when will it be introduced?
hogi
Level XIII
mia_stephens
Status changed to: Delivered
This change was made in JMP 18. Thanks for the suggestion @hogi !
hogi
Level XIII
Thanks @mia_stephens . This will facilitate JSL scripting a lot for new Jmp user
did you notice that
<< get script()
still returns the script without semicolon?
