☑ cool new feature
☑ could help many users!
☐ removes a „bug“
☐ nice to have
☐ nobody needs it
#myTop10_2022
Please add this functionality to JSL editor:
When a user Double-Clicks a bracket, the code inside the brackets is analyed, clustered ind highlighted with differnet colors.
Example for "if":
- conditions are highlighted green to separate the code blocks in-between
- else code is highlighted red to separate is from the other code
https://community.jmp.com/t5/Discussions/JSL-if-else-gt-find-the-commas/m-p/573510/highlight/true#M7...
Similar highlighting could also be applied to many other functions:
Match: highlight each match to separate the code blocks.
Substitute: highlight the search patterns to separate the replacement blocks
more wishes submitted by
