View Original Published Thread
new Column Property: Value Markers
☐ cool new feature
☑ could help many users!
☐ removes a „bug“
☐ nice to have
☐ nobody needs it
#myTop10_2024
In Column Properties, one can define the colors and the order for specific "values" - but ist astonishing that JMP is lacking a possibility specify the marker settings as well.
Therefore, the user has to synchronize the settings manually for every single plot:
https://community.jmp.com/t5/Discussions/color-settings-for-quot-missing-quot-values/m-p/565346/high...
"Marker by Column" sounds almost like the missing feature - but a closer look shows that the functionality is "related", has little overlap and several disadvantages.
My wish: An additional column property setting to specify Marker settings for specific column values.
The functionality should be analog to "value colors", but for markers.
The benefit:
The user can specify (colors and) markers for specific values and make them more visible (e.g. highlight and differentiate between different fail categories, show "pass" with a tiny standard marker).
WHY IS THIS IMPORTANT?
"Marker by Column" uses row states to assign Markers.
the issue: The setting is active for ALL (!!!) Plots - not just the plots where a specific column is used as overlay.
With the help of Value Markers, one gets the chance to specify different sets of markers for different columns.
This is already possible for Value Colors and Value Order. Why is it not possible for Markers.
14 Comments
hogi
Level XII
thanks
hogi
Level XII
@mia_stephens , @Sarah-Sylvestre .
  1. It's very difficult and time-consuming to create multiple Plots manually with consistent settings.
  2. there are several bugs when assigning settings manually to Graph Builder plots.
    -> An innocent user might create wrong plots
For "Color", I love the column property Value Color and I use it wherever I can.
--> To fix the issues #1 & #2, please add Value xyz for all the legend settings xyz :
- Value Marker
- Value Marker Size
- Value Line Style
- Value Line Width
- Value Pattern (for bar graphs)
- Value Transparency
anything else?
hogi
Level XII
For me, value markers feel like a logical step.
Missing value markers feels like "something useful | obvious is missing".
Is there a general issue that makes it impossible to implement value markers in JMP?
Maybe a legal issue?
hogi
Level XII
@DavidWhite
#DiscoverySummit2025
thanks for the discussion today on this topic.
