  • Register to see how to import and prepare Excel data on Jan. 30 from 2 to 3 p.m. ET.
make columns more distinct (💚)
☐  cool new feature
☑ could help many users!
☐ removes a „bug“
☐ nice to have
☐ nobody needs it
sometimes it's hard to find the right column again and again.
some suggestions to make it easier:
- define special colors for special columns (or groups):
- make the vertical line between groups thicker
21 Comments
hogi
Level XIII
the column color could also be used to highlight columns of larger interest - like illustrated here:
Craige_Hales
Yes, colors for column headers!
@hogi  For now, try the scroll-lock for a few important columns to keep them pinned to the left edge of the grid.
SamGardner
Level VII
Thanks for the suggestion @hogi .  We are investigating the feasibility of this feature request and if it something we will pursue.
SamGardner
Level VII
hogi
Level XIII
i just detected this wish:
https://community.jmp.com/t5/JMP-Wish-List/Set-background-color-in-column-header-column-names/idc-p/...
Seems to be quite the same - could you please merge both wishes?
[edit] and here the grandfather o this wish:
Suggestions for new features to aid in better table organization
SamGardner
Level VII
Our development team is looking into this and we may be adding this as a new feature in upcoming versions of JMP.
hogi
Level XIII
Thanks a lot :)
Besides highlighting columns in the column list on the left, platforms could also benefit if Filter Col Selectors and Col List Boxes will share the same color coding.
FN
Level VI
This wish also focuses on having a better organization of columns, not by color but by hierarchy.
https://community.jmp.com/t5/JMP-Wish-List/Improved-column-organization-in-datatables-multiple-level...
In general, working with several columns in JMP, common in manufacturing data, is really challenging.
OrganicSocrates
Level I
+1 for column header colors.
Audrey_Shull
I can confirm that column header colors are under active development for the next major release of JMP (JMP 18).
