  • Use World Cup data to build models, explore spatial relationships, and create informative visualizations in JMP. Register. July 17, 2 pm US Eastern Time.
make Handle in graphics script easier to click
Larger marker for Handle - the handle function makes a tiny square marker which is hard to hit with the mouse. Make it easier to drag a handle without hitting the exact center of the marker.
New Window( "Example",
    exx = 20,
    exy = 50;
    Graph Box(
        Frame Size( 200, 200 ),
        Handle(
            exx,
            exy,
            exx = x;
            exy = y;
        Circle( {0, 0}, Sqrt( exx * exx + exy * exy ) );
the bottom edge of the square marker seems out-of-bounds.the bottom edge of the square marker seems out-of-bounds.
2 Comments
kayleewarren
@Craige_Hales Thank you for your suggestion! We have captured your request and will take it under consideration.
hogi
Level XIII
Same for Drag Markers!
One can increase the marker size - but little help :  one still needs to drag the Drag Marker at the center.
