Hi. I have 2 requests related to the "<< Close Side Panels()" command. First, my specifics:
JMP Pro 16.2.0
1. Working with JMP support (case TS-00010957), we have discovered that it appears to affect -all- tables that are opened after the command, and not just the table that the command is sent to. That is: dt << Close Side Panels(1) will close the side panels on all subsequently opened tables, and not just dt. This code illustrates the issue:
Names Default To Here(1);
dt = Open("$SAMPLE_DATA/Blood Pressure.jmp");
dt << Close Side Panels(0);
Wait(2);
dt << Close Side Panels(1);
Wait(2);
Close(dt, NoSave);
dt2 = Open("$SAMPLE_DATA/Big Class.jmp");
On my system, after the script is run, both dt and dt2 have their side panels closed, despite never issuing the command for dt2. JMP Support has confirmed this behavior is fixed in JMP17, so I'm issuing this wish list item just in case.
2. JMP appears to save the open/closed state of the side panels for each table, such that even after the table is closed and reopened, the table will retain the condition it was in prior to closing (I'm not sure if this ability to recall persists if JMP is closed and reopened, or if computer is restarted. Might be worth investigating). If this is the intended behavior, then I would ask that the Script Editor and Online documentation for this command be updated to make sure the user understands this. This will prevent confusion.
Thanks!
