grab more report settings via Enhanced Log / Workflow Builder
☐ cool new feature
☐ could help many users!
☑ removes something that feels like a bug
☐ nice to have
☐ nobody needs it
Outline close orientation for column switcher issue
Enhanced log/Workflow Builder  should be aware of the outline close orientation and the horizontal (0/1) settings specified in a report.
Why is this idea important?
If a user generates a report and re-creates it via auto-generated Script / Workflow Builder / Dashboard Builder, the report should look the same.
4 Comments
hogi
Level XIII
TS-00142187
hogi
Level XIII
I believe this is a bug.  It turns out the outline box used for the column switcher is a different object than the "usual" outline box.  This particular object is not documented in the SI.  Additionally, while not everything is currently captured by the action recorder, the goal is to have it so.  In this case, the action recorder is not capturing that the orientation should be horizontal.  I will create a bug report for development to have these two items addressed in a future release.
-> no feature request, it's a "bug"
Status changed to: Archived
Archiving because this is a bug.
hogi
Level XIII
Ok, let's hope that the "bug" gets fixed
