  • Use World Cup data to build models, explore spatial relationships, and create informative visualizations in JMP. Register. July 17, 2 pm US Eastern Time.
for each row(data update=1, ...)
When writing jsl scripts that update large tables it is cumbersome to add a <<begin data update() and <<end data update() on either side of the for each row().
I would like to see some functionality for <<begin data update() and <<end data update() embedded in the for each row() function.
Why is this idea important?
This will make code more readable and faster if users write all for each row() using the new functionality.
May improve GUI speed as table updates will be faster.
I am using JMP 16.2
4 Comments
Hi @bswedlove, thank you for taking the time to submit this idea! We will review your request and keep you updated on its status.
bswedlove
Level IV
Thanks!
hogi
Level XIII
nice idea.
this will also lead to much nicer scripts via Enhanced log when Recode is used!!!
maybe even something shorter than data update= ?
  • w=1 / write=1
  • fast=1
  • hs=1  (hs for high speed)
hogi
Level XIII
same for Python data access - make the issue disappear by institutionalizing the solution:
Python in JMP: dataframe column to datatable column best practices and computation speed implication...
