  • Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
efficient data cleaning- for simple replacements
Actually I came on the community to see if there was already something new about this, still not certain whether I'm missing something now built-in...
I want to, using JSL, replace certain values (like -999 or >998) with missing across many columns (possibly all numeric columns). It's not hard to script this up. nice example of what I mean and what I'm currently doing here:
https://community.jmp.com/t5/Discussions/Deleting-cell-values/td-p/46957
But (1) this seems like something that could be fairly common so possibly worth it's own built-in function (or ability to script the recode ability)  and (2) it's not lightning fast on large data so if it's possible maybe a more resource efficient underlying method could be part of such a solution.(?)
3 Comments
gzmorgan0
Super User (Alumni)
A wish list item requested a while ago was to enable column properties be assigned to a defined table group column( a ist of columns).
An alternative that is pretty simple is to select the columns needing "cleaning". Copy to the clipboard a missing value code property, then send the the JSL message Paste Multi Columns Properties to the data table. The attached script shows a matrix method for replacing values without a for-loop, however, I find the Missing Values Code more useful: the database (original) data values are not modified, more than one value can be set, and original values can be recovered.
Names Default to Here(1);
//create example table
dt = New Table( "example",
	Add Rows( 3 ),
	New Column( "A",
		Character,
		"Nominal",
		Set Values( {"", "", ""} )
	New Column( "B",
		Character,
		"Nominal",
	New Column( "C",
		Character,
		"Nominal",
	New Column( "x_1",
		Numeric,
		"Continuous",
		Format( "Best", 12 ),
		Set Values( [1, 2, 8] )
	New Column( "x_2",
		Numeric,
		"Continuous",
		Set Values( [8, 8, 8] )
	New Column( "x_3",
		Numeric,
		"Continuous",
		Set Values( [2, 8, 2] )
	New Column( "x_4",
		Numeric,
		"Continuous",
		Set Values( [7, 8, 5] )
	New Column( "x_5",
		Numeric,
		"Continuous",
		Set Values( [2, 8, 3] )
	New Column( "x_6",
		Numeric,
		"Continuous",
		Set Values( [2, 8, 8] )
	New Column( "E",
		Character,
		"Nominal",
// this replaces values
cnme = dt << get column names(numeric);
dt << select Columns(cnme);
mat = dt << get as matrix;
mat[loc(mat==8)]=empty();
dt[1::nrow(dt),cnme]=mat;
//Close dt and rerun the code to create dt
set clipboard("{Add Column Properties(Set Property(\!"Missing Value Codes\!", {8}))}");
dt << Paste Multi Columns Properties;
//The value of 8 appears, but is treated as missing.
//There is a request that column property settings can be assigned to a column group
XanGregg
In case it's faster, data table subscripting is also an option:
dt = open("$SAMPLE_DATA/Big Class.jmp");
r = loc(dt[0, 4]==61)
dt[r, 4] = .;
Ryan_Gilmore
Community Manager
Status changed to: Archived
