  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
delete column: safe mode
☑ cool new feature
☑ could help many users!
☑ removes something that feels like a „bug“
☐ nice to have
☐ nobody needs it
When a user renames a column, Table Scripts get automatically updated.
When a user deletes a column which is used in a table script, JMP warns the user if the column is used in column formulas.
But a table script will die without notice.
a) it takes a long time for the user to find out why the table script is dead.
b) it takes some effort to create the column again (worst case: not possible to create the column again)
Before deleting a column, please check if the column is used in a table script - and show a warning.
Names Default To Here( 1 );
Current Data Table() << copy table script( "no data" );
tableScript = Eval( Eval Expr( Parse( Expr( Get Clipboard() ) ) ) );
col_names = Current Data Table() << Get Selected Columns();
tableScriptList = Substitute( Name Expr( tableScript ), Expr( New Table() ), Expr( List() ) );
tableScriptList = Filter Each( {part}, tableScriptList, Head( Part ) == Expr( New Script() ) );
found = 0;
For Each( {col}, col_names,
	For Each( {myScript}, tableScriptList,
		If( Not( Is Empty( Eval( Eval Expr( Extract Expr( myScript, Expr( Name Expr( col ) ) ) ) ) ) ),
			Caption( {100, 200}, "column \!"" || (col << get name()) || "\!" found in script: \!n" || Arg( myScript, 1 ) );
			found = 1;
			print("found!!!");
			Wait( 1 );
If( Not( found ),
	Caption( {100, 200}, "no column found.\!N ->cols can be deleted" );
	Wait( 1 );
Caption( remove )
Why is this idea important?
Just imagine how many JMP users killed a table script by "accidentally" deleting a column.
switching to "safe mode" will safe many users from the same issue.
1 Comment
Sarah-Sylvestre
Level V
